[SOLVED] Wierd Monitor brightnes
metalhead 93
27
i changed my gpu to gtx 1060 and suddenly the brightnes on my monitor is way of the colllors look washed out..i tried adjusting it in nvidia control panel but it doesnt help i also tried adjusting it on my monitor but it helps only little..what should i do
Check the refresh rate. Usually, 50-60hz on my monitor makes all the colors lighter. I overclocked my monitor to 75hz and it has better colors now. Try adjusting your refresh rate and see if that helps.
