hi
I have recently purchased a laser mouse .
model number :Laser Precise (1600 CPI)
manufacturer: iball
before this i had a MS basic optical mouse .The problem with the mouse is that is sort of lags in between or get hung in the center of the monitor when i drag it from left to right with a speedy movement (faster than normal movement) ,but this problem occurs only when it is connected to the usb port . When i use a USB to PS2 converter and connect it to the pc it works almost fine with no hanging .I even tried to increse the sampling rate in the control panel>mouse>and advanced setting in the hardware options ,but to my surprize there were no such settings when i connected it through the usb connector .So i further looked in the my computer>properties >hardware for the usb connector conflicts .The resources allocated to the usb connector were only 23% and for other ports is was 10% bandwidth allocated phew!.The problem still remains that why is there a lag or stopping of the mouse when connected through USB and not in PS2 connector .Please help me . if you need any more clarification do ask me
manufacturer: iball
