Weird PC noise, resonance frequency?
I have this wierd low level hum hum hum noise that comes from the computer, I'm thinking one of the fans, either cpu fan, sys fan, or gpu fan but I don't know which one. When I'm setting down, randomly I will hear what sounds like a low level humming noise that increases in intensity and frequency (like the noise those AC units makes in the summer) almost like there is some tessellating resonance frequency going on where the vibrations and fan "rev" noises are rhythmatic.
Then every time I put open the computer case while the computer is running to investigate and to get a closer hearing of it, the rhythmatic noise seems to magically go away.
My theory is that by opening the case, either by changing the structure of the case or interrupting the airflow patterns that had developed that I got rid of the by disturbing the resonance frequency
Once I put the case back, and I sit down, after a while the noise comes back.
Is my ears imaging things and I need to go to the doctor, or is it my computer?
