i have a wifi 6e router tenda rx27 pro when i connect to the 6ghz band (i have the bands separated cause i use win 10) it fails to connect but if i connect to the 5ghz band it works first try if i spend some time on 5ghz and then try to connect to the 6ghz it works how can i make it work without this workaround
wifi card is the preinstalled one in my msi b650 edge wifi motherboard
