Wifi Adapter Replacement Compatibility
Mar 31, 2018
Hello,
I have an old Toshiba Satellite c650 (PSC12C-05U00S) that I've re-purposed and I want top replace the wifi card in it to something newer that supports faster wifi speeds and Bluetooth. However everything i'm reading tells me that the BIOS might affect what I can use to replace it and i'm not getting a clear answer on either what i can replace it with or what i would have to do to replace it. Any suggestions would be greatly appreciated
Know what wifi adapter is in there?
The next might show,
download hwinfo,
install and open it=click run,
close the top window which is the system summary,
in the main window at the left top click "save report",
at the bottom of the next window check "short text report",
after that you'll see what's in the pc,
Just need the wifi adapter.
It will probably be something like this,
https://pcpartpicker.com/product/fhPzK8/intel-wireless-network-card-7260hmwwbr
and this is probably what you look for. Can also open the laptop and look for confirmation. Other option would be an usb adapter,but getting one with bluetooth as well will be the hard part i think.
Latest posts
