Hi all. This is my first post here, so please forgive me if there is another board where this topic would be better suited, I figured this would be best place based on the topics I saw.
I have an HP Spectre x360 2-in-1 ultrabook that is having a very annoying problem with the WiFi antenna disconnecting from the wireless card. I don't know which genius designed this, but the wires for the antenna run right through one of the hinges, so between opening/closing the laptop and just general movement of the laptop from place to place, one of the antenna wires keeps physically disconnecting from the wireless card.
It looks something like this (not my actual laptop, but pretty much exactly what I'm looking at):
This of course results in a very weak signal, and either slow speeds or no connection at all. It's also a huge pain to fix as reconnecting the antenna requires turning off the pc and unscrewing the 8 t4 screws from the bottom of the laptop. It occurs regularly enough that I actually bought a separate t4 screwdriver to carry around in my bag so I don't have to lug my regular toolkit around with me everywhere I go.
This thing is my primary machine for school and work, so I'd really like to avoid sending it to HP or something for an extended period of time (and potentially significant $$$). What I'd really like is a way to more securely/permanently connect the antenna to the wireless card. Is there any recommended way to do this? Soldering? Any sort of component-safe adhesive? This laptop has been such an amazing machine in every other aspect, but this problem is driving me up the wall.
