Question wifi antenna not working
OfficialKapn
122
Hi, everyone,
So I wanted to turn off the led of my motherboard when the PC is off and messed up with Erp settings, now my motherboard is not detecting the wifi antenna anymore.
Reinstalling wifi drivers as well as setting bios settings to default isn't helping.
How could I fix it??
Thanks
Make sure the connections are firmly attached. Your previous USB changes should not have affected unless you disabled the on-board wi-fi in the BIOS.
If necessary, you could reset the BIOS to its default state to see if that resolves the issue.
I reattached it a couple of times and set bios to default again.
it happened to me once before but after I set bios to default it was normal again, but now it's not helping.
