Wifi connection to laptop keeps dropping
RohitDongre
I have been having this problem for a few days now. I have a iB-WRB300N router. My laptop which is connection to the router frequently loses access to internet while I can use the same WiFi connection without a problem at the same time. Note that the laptop doesn't lose connection with WiFi router but just the internet connection. This happens for about 20-40 seconds in every few minutes and then everything gets back to normal. I use Windows 10 on my laptop. Please someone help if you can as this is annoying me very much.
Do other computers lose internet connectivity or does only the laptop lose its internet connectivity?
Could that the issue is between the laptop and router. Just takes longer to re-establish the necessary connections/handshakes while online.
Try moving closer to the router for test purposes.
Try another wireless frequency/channel if available - may be some local interference.
Overall, see if you can narrow down the circumstances involved as a matter of elimination.
As always, check all physical connections between devices. E.g., incoming ISP connections, connections between modem and router.
Any source of disruption (wired or wireless) may be the reason Your entire network is likely being affected.
And your laptop may just...
And your laptop may just be more sensitive to wireless interference and/or be slower to recover.
