Wifi disconnecting and wont reconnect
Henry_34
Commendable
Mar 30, 2016
Hi
My laptop is constantly disconnecting itself from the internet. It started out as the connection would deteriorate slowly (measured as ping climbing in csgo), if i troubleshooted the problem it would display that the wireless network adapter was reset, my ping would then return to normal until the process started again. Recently it has just been flat out disconnecting from internet and will not reconnect unless i troubleshoot the problem again.
I can post Network Diagnostics Publisher details if that is needed.
okey then its problem with your PC, try to boot into the safe mode with F8 key or use this guide:
http://www.howtogeek.com/howto/windows-vista/force-windows-to-boot-into-safe-mode-without-using-the-f8-key/
then test your ping, flash won't work in safe mode so use this site to test ping without flash
http://beta.speedtest.net/
First we need to point out whether this problem is with your Wifi router itself or with the wireless connection of your laptop, to do so:
1. try to connect with mobile device or other device to your wifi router and observe the ping, is it OK? ,or still suffering ping latency and drops?
2. if it's OK then it should be problem with your PC's Wifi connection,to be sure also try to connect your PC's wifi to other routers or mobile hotspot and check if the ping is OK.
then we can have a clear view of your situation.
