wifi does not work but it did
Computer: Lenovo ideapad
Sys: Suse 15.0 Leap
My wifi driver stopped working.
It was good for some months but now i cannot see it from my computer.
I use Network Manager and when I start it, it showes the wired connections only. At the same place i see several wifis with my cellphone so they are exist.
Can anyone help me?
thanx a lot.
Oct 12, 2018
Thank you. Problem solved, but the reason is unknown.
I went back to the shop where I bought the laptop, and the guy changed the hard disc to test if it was a hardware or a software failure. He installed a new Windows and the wifi worked. I put my winchester back and the wifi was good with my system as well.
Somy guess: some of the programs (cannot guess which one and how managed it) caused a fault which switched the wifi off on the hardware in a way which is not intended to handle. The new installation solved the problem.
