Hi Guys,
I'm seeking some help regarding a new WavLink Extender.
I am trying to connect a Yamaha MusicCast receiver at my pool area, and it isn't picking up the signal from any of my Unifi WAP's from the house (although phones etc do)
So I successfully installed the WavLink extender down at the pool area and it picked up the Wifi Signal up from the house, and I could connect with the MusicCast device on the new 'Wi-Fi-2.4ghz EXT' SSID, however it has created it's own IP range, 192.168.10.xx, so I cant connect to the MusicCast receiver from inside the house when on the regular WiFi network which are all on 192.168.99.xx . (which is the whole point, so people can control the pool music form inside the house on the wall tablet control).
I have been given advice that this is because the extender is in 'gateway mode' rather than 'bridge' mode, and the extender is doing its own DHCP thing, so I have reset the extender and tried to set it up in bridge mode, but once I go through that setup process, I can't connect to the extender (either on the musiccast device or on my phone).
I have detailed the steps I have taken below, with some comments, hopefully someone can point me in the right direction and tell me where I'm going wrong.
3) It's doing its thing: View: https://imgur.com/XcsThIT
4) New SSID's are viewable: View: https://imgur.com/xVDT0Vz
5) When I try to connect on phone it just spins on this: View: https://imgur.com/Zl5NH5T
Any help would be super appreciated.
Thanks all
- Reset the Extender. Then search for the extender in my phone Wi-Fi: (wavlink-ac)
View: https://imgur.com/Lw8lbTS
- Set up in bridge mode as follows.
View: https://imgur.com/GbD0Lkw
Thanks all
