Question Wifi keeps disconnecting when usb is plugged in
Sep 2, 2020
5
I have a ryzen 2400g with a asus a320m-k motherboard. 16Gb of ram. I am running 3 1080p displays on the iGPU using a usb 3.0 to vga adapter. I have a tp link wifi pcie adapter (tl-WN881ND) installed. I have been running into a problem where if a connect my usb hub or the usb to vga adapter my wifi still shows all the networks and I can try to connect to them but windows 10 keeps failing to connect. Sometimes it connects but with no internet access.
I thought it was because i have to many usb devices but after buying a pcie usb card I still have the sam problem. When the hub/adapter are disconnected the wifi works fine.
Any solution/suggestions would be greatly appreciated.
