If you open the Device Manager and look under the Network Adapters tab does it show any devices; if so which ones and do the devices Properties indicate that they are working properly. Also does your motherboard's bios indicate that wifi and bluetooth are enabled?Hello, I have the Gigabyte B550I Aorus pro ax motherboard, but the wifi isn't being detected. I have installed the Intel adapter drivers for wifi and bluetooth, but it still doesn't work. Can someone please help me out?
How do I check if Wifi and bluetooth are enabled?If you open the Device Manager and look under the Network Adapters tab does it show any devices; if so which ones and do the devices Properties indicate that they are working properly. Also does your motherboard's bios indicate that wifi and bluetooth are enabled?
When you boot your computer press whatever key the screen says to press to enter the bios (usually the Del key). Then navigate the bios menus to find the entries for wifi and bluetooth and if necessary set them to Enabled; save and exit the bios.How do I check if Wifi and bluetooth are enabled?
Network Adapters:
Realtek Gaming 2.5GbE Family Controller
Wan Miniport (IKEv2)
Wan Miniport (IP)
Wan Miniport (IPv6)
Wan Miniport (L2TP)
Wan Miniport (Network Monitor)
Wan Miniport (PPPOE)
Wan Miniport (PPTP)
Wan Miniport (SSTP)
This is all I see. View: https://imgur.com/a/9CFdedrWhen you boot your computer press whatever key the screen says to press to enter the bios (usually the Del key). Then navigate the bios menus to find the entries for wifi and bluetooth and if necessary set them to Enabled; save and exit the bios.
Do you have an ethernet cable connected? Since ethernet supersedes wifi you would only have access to wifi when the ethernet cable is disconnected since you don't need wifi when you have ethernet.This is all I see. View: https://imgur.com/a/9CFdedr
