as i mentioned above, ( i have already looked for existing questions, but i didn't really find nothing similiar) i'd like to know if would be possible to utilize a repeater AC750 RE200 ( with an ethernet port available ) as "bridge" and acess point at the same time, i mean :
would, the repeater,be able to connecting into my computer through ethernet and, at the same time, repeate it's signal for other devices as it normally would??? or it will stop its function as repeater to bridgin it through ethernet?
maybe i would need a router for this? could you write in case, if possible, any example of any router with simliar wireless performance( and of curse, the "repeater" function)?
any info :
Router radio connection type ( main signal ) : 802.11N
i couldnt use any type of powerline due to electricity problem ( i suppose they have to stay in the same home)
my knowledge about networking are really poor, so (until now) im considering routers/repeaters characteristics relying on its performance per dbi like the scheme below ( from the ac750re200)
2.4ghz
270M: -70dBm@10% PER
130M: -70dBm@10% PER
108M: -73dBm@10% PER
54M: -75dBm@10% PER
11M: -86dBm@8% PER
6M: -92dBm@10% PER
1M: -94dBm@8% PER
it is right? or i would consider others characteristics? im making this discuss/question cause im attempted to buy a repeater but i dont know if it will serve to solve my connection problem
im sorry for my bad english, this is not my native language.
thanks for the help in advance. 😀
any info :
2.4ghz
54M: -75dBm@10% PER
11M: -86dBm@8% PER
6M: -92dBm@10% PER
1M: -94dBm@8% PER
