Yesterday I received a WiFi repeater that I had ordered from Amazon, and after I had completed the setup I experienced problems with the signal between the repeater and my main router.
1) Signal drops occasionally between my laptop and the repeater
2) Internet connection is considerably slower when connected to the repeater (about 10% of the speed I get from my main router - speedtest.net) although the wireless signal is perfect when testing both
3) I can only access the config page on the repeater BEFORE it is setup to the existing WiFi. As soon as I've set it up, I cannot access it anymore.
When running the setup for the repeater it shows that the connection to my existing WiFi is 100%, so the signal seems to be fine.
The repeater I bought is this an equivalent of this - http://www.amazon.co.uk/Repeater-amplifier-including-connection-standards/dp/B006CKWZT6/ref=sr_1_2?ie=UTF8&qid=1363604988&sr=8-2 -
and my router is a Thomson TWG870U with the latest firmware. The distance between the two are less than 10m and my laptop is in between them both.
I'm starting to think the product itself (the repeater) is just a piece of junk. However, I would very much appreciate of someone knew what the problem could be!
Thanks in advance,
Thanks in advance,
