Hi, I already posted about my problem on reddit, but nobody there was able to really help me. Here is the original question from my side; I added everything I've learned at the bottom of this post. As the reddit thread might include some other useful information, here is the link for it: https://www.reddit.com/r/wifi/comments/abuef0/wifi_speed_fluctuates/
As the title says, my internet speeds are fluctuating A LOT in a short period of time. Sometimes I get 30+ Mbit/s, half a minute later they're at <1 Mbit/s. There are lots of devices connected in the household, but the drops seem to be too big to be simply down to a lot of devices. When the download speed is so low, the upload speed still stays quite high (~10 Mbit/s probably); no idea if that means anything.
It started about 1-2 months ago without any changes made to the network. There are different access points in the house, the problem occurs being connected to all of them and on multiple devices (2 laptops, 1 Android phone, 1 PlayStation 4).
In forums and other threads I found out that interferences are a common cause for fluctuating wifi, therefore I switched to 5 GHz only on the AP I use the most. In the screenshot I attached you can see all the other networks around; all of them are on 2.4GHz. This didn't fix the problem, but only made my connection worse (I assume it's because the AP is behind a wall and 2.4 GHz passes through walls more easily).
So to summarize:
-) it suddenly started to fluctuate
-) it's most likely not down to interference
-) it's most likely not down to the devices connected to the Wifi
-) it's most likely not down to the APs
Screenshot explanation:
green -> APs in the network
"Durchs..." -> average
Kanal -> channel
Breite -> block size (20 vs. 40 MHz steps)
Anbieter -> AP manufacturer
I tested the speed with both speedtest.net and Google's speed test
Edit:
-) I performed a test at dslreport.com that indicated a bufferbloat problem:
-) I performed a iperf test that showed fluctuating network speeds: https://i.imgur.com/a7Qs0p7.png[/img]
I would really appreciate your help; as you can see, I'm really not an expert and I'm really unsure what all these results mean.
Edit 2: My router/modem seems to be a ISP branded technicolor TG588v
So to summarize:
Kanal -> channel
Edit:
