L laurenbain246 Prominent Sep 13, 2017 1 0 510 Sep 13, 2017 #1 My wifi only connects when I'm directly under the router, the wifi works with everything else including PC's. It says I need to reinstall my network controller but I'm not connected to the internet and it says there's nothing that can install it.
Solution hang-the-9 Sep 21, 2017 You can download the drivers using another computer and run the setup on the one with the issue.
hang-the-9 Titan Mar 25, 2010 60,372 1,078 152,940 Sep 21, 2017 Solution #2 You can download the drivers using another computer and run the setup on the one with the issue. Upvote 0 Downvote Solution
