WIFI works but Ethernet connection not working.
May 10, 2018
Alright I'll do my best to explain what happened and some events may be unrelated but due to them happening at the same time I think they're worth mentioning.
Was driving back to the apartment to be completely blocked off by the fire department because the center office building was on fire. Walked back home to find our wifi was down. Not sure if there's a relation there (comcast) and could just be coincidence.
AT&T is also installing their new fiber cables into the apartment complex today. Unsure if related.
Went to bed and now our wifi works but our ethernet connection doesn't. Also when turning on the wifi I had to give my router a new password and security questions for some reason. I tried logging onto the router and according to it the connection is good.
The wifi wasn't working 100% correctly and it would only load some websites so I ran a network reset from network settings and that fixed the wifi problems but ethernet still down.
I tried looking at other threads on this topic but didn't run into a solution for what was going on. I tried swapping the cables and we have multiple computers here all with the same issue.
Manufacturer: Intel Corporation
Description: Intel(R) Ethernet Connection (2) I219-V
Driver version: 12.15.22.6
Physical address (MAC): 1C-1B-0D-A0-49-0B
Physical address (MAC): 1c:1b:0d:a0:49:0b
Status: Not operational
Maximum transmission unit: 1500
IPv4 address: 169.254.223.238/16
IPv6 address: fe80::3d98:aa69:f35b:dfee%4/64
DNS servers: fec0:0:0:ffff::1%1, fec0:0:0:ffff::2%1, fec0:0:0:ffff::3%1
Connectivity (IPv4/IPv6): Disconnected
Name: Local Area Connection* 10
Description: Microsoft Hosted Network Virtual Adapter
Physical address (MAC): a0:63:91:a8:a7:20
IPv4 address: 169.254.101.112/16
IPv6 address: fe80::79a8:f2eb:4b10:6570%28/64
Name: Local Area Connection* 11
Description: Microsoft Wi-Fi Direct Virtual Adapter
Physical address (MAC): a0:63:91:a8:a7:21
IPv4 address: 169.254.144.114/16
IPv6 address: fe80::d43d:2cbe:8fc0:9072%33/64
Description: NETGEAR WNDA3100v3 N600 Wireless Dual Band USB Adapter
Physical address (MAC): a0:63:91:a8:a7:27
Status: Operational
Link speed (Receive/Transmit): 600/300 (Mbps)
DHCP enabled: Yes
DHCP servers: 192.168.0.1
DHCP lease obtained: ‎Thursday, ‎May ‎10, ‎2018 9:08:46 AM
DHCP lease expires: ‎Friday, ‎May ‎11, ‎2018 9:08:46 AM
IPv4 address: 192.168.0.15/24
IPv6 address: 2601:807:8700:7100:e10c:db5f:63a1:1898/64, 2601:807:8700:7100:5514:337f:c66a:8cfb/128, fe80::e10c:db5f:63a1:1898%22/64
Default gateway: fe80::a240:a0ff:fe3e:f17a%22, 192.168.0.1
DNS servers: 2001:558:feed::1, 2001:558:feed::2, 75.75.75.75, 75.75.76.76
DNS domain name: hsd1.in.comcast.net.
DNS connection suffix: hsd1.in.comcast.net.
DNS search suffix list:
Network name: NETGEAR31-5G
Network category: Public
Connectivity (IPv4/IPv6): Connected to Internet
Name: Teredo Tunneling Pseudo-Interface
Description: Teredo Tunneling Pseudo-Interface
Physical address (MAC): 00:00:00:00:00:00:00:e0
Status: Operational
Maximum transmission unit: 1280
IPv6 address: 2001:0:9d38:6ab8:3089:2a2b:b699:7732/64, fe80::3089:2a2b:b699:7732%38/64
Description: 802.11ac Wireless LAN Card
Physical address (MAC): 10:da:43:17:d3:08
Status: Not Present
Maximum transmission unit: 0
It looks like your wired ip is public. Make sure your computer is plugged into a working router with a NAT.
The ip should be 192.168.x.x on your computer.
If you have a modem/router combo. Log into it and check the settings to see if it's in passthrough mode. If that's your only router you don't want that.
