WIFI works on all devices except for my pc
lazic.davidd
5
I can connect to a new wireless network from my laptop and mobile phone, but when i try to connect it displays "no internet" status with yellow triangle. I took my pc to my friend to download latest drivers, they were already installed; then i tried to use his wireless network and it connected without a problem.
here's ipconfig:
Windows IP Configuration
Host Name . . . . . . . . . . . . : DESKTOP-325H91L
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller
Physical Address. . . . . . . . . : 00-26-18-5C-FE-78
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wi-Fi 2:
Description . . . . . . . . . . . : Realtek 8185 Extensible Wireless Device #2
Physical Address. . . . . . . . . : 00-22-CF-33-5B-E4
Link-local IPv6 Address . . . . . : fe80::e5f1:b7ef:2f32:7803%2(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.120.3(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 33563343
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-21-5B-AF-FB-00-26-18-5C-FE-78
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{04341512-92AF-4C2A-99C9-33E687255494}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
I tried to ping 8.8.8.8, but failed
using windos 10
for some reason sometimes it shows me like it is connected but it says unidentified network, though i still cant connect or ping anything. i tried connecting to my phone hotspot also without any success.
Maybe try restarting router, if this dosent work try resetting your router if you are comfortable doing so, it shouldnt mess up any settings but be wary of this issue
I cant physically access router but i do believe that it is not a router problem because i took my pc to a friend and tried his wireless network, same thing happened. cable works without a problem
