Will 120mm cooler fit into my case?
Oct 7, 2018
6
Hi, I'm currently refurbishing my pc by adding a new, m/b, new gpu, new cpu and cooler. However, Im not sure on whether the cooler I have chosen will fit into the case. Is there any way to check? Because I have had a look online and it says my case can fit a 120mm fan but the radiator I have chosen is bigger than that.
Does anyone know how to check it will fit without buying it?
Parts:
Cooler: http://www.coolermaster.com/cooling/cpu-liquid-cooler/masterliquid-120/
Case: http://www.coolermaster.com/case/mid-tower/haf-912-combat-windowed-version/
Oct 7, 2018
6
Yeah but thats for a air cooler not the water cooler I have chosen. I need to know if the radiator and fans will fit.
Karadjgne
Herald
That haf-912 has space to mount 6x 120mm fans. That means it'll also mount that 120mm cooler in 1 of 6 different places. You have all kinds of space. Most common mounting position is top rear or rear exhaust. Personally I'd mount it as rear exhaust, with 2x top exhaust fans and the 200mm option as intake. That's a massive amount of possible airflow, so fan speeds can be lowered, which lowers fan noise.
Oct 7, 2018
6
Thanks very much, just to check. Where is the rear exhaust fan slot located?
