msproject251 Reputable Dec 14, 2015 347 0 4,810 Mar 16, 2016 #1 I'm buying an extra 8gb ram and i currently have corsair vengence 1333mhz ram and i was wondering if it will work next to another corsair vengence ram but this time 1600mhz?
Solution dextermat Mar 16, 2016 +1 wolfshadw, most likely downclock or you can try and overclock the 1333. But the best would be to get same memory to rule out trouble
Wolfshadw Titan Moderator Aug 3, 2006 28,221 1,513 133,290 Mar 16, 2016 #2 *IF* if works (and that's not a guarantee), I believe the 1600Mhz RAM would slow down to 1333Mhz to match your other RAM module. -Wolf sends Upvote 0 Downvote
dextermat Splendid Sep 21, 2007 4,957 0 24,960 Mar 16, 2016 Solution #3 +1 wolfshadw, most likely downclock or you can try and overclock the 1333. But the best would be to get same memory to rule out trouble Upvote 0 Downvote Solution
