Thepigdude Honorable Jan 26, 2014 132 0 10,690 Jul 26, 2016 #1 As the question asks i plann on putting in a 280mm aio and i wanted to put another 140mm fan but I still need the optical bays so i was wonder ing if a 140mm fan will fit with the bays still in
Solution renz496 Jul 29, 2016 did you intend to use all the 5.25 slot? looking from this picture it seems you can do it even if you put the optical drive on the top most slot https://www.techpowerup.com/reviews/Phanteks/Enthoo_Pro/images/innerside1.jpg
renz496 Champion Jun 16, 2009 14,337 239 53,090 Jul 28, 2016 #2 did you already have the hardware or intend to get one? Upvote 0 Downvote
renz496 Champion Jun 16, 2009 14,337 239 53,090 Jul 29, 2016 Solution #4 did you intend to use all the 5.25 slot? looking from this picture it seems you can do it even if you put the optical drive on the top most slot https://www.techpowerup.com/reviews/Phanteks/Enthoo_Pro/images/innerside1.jpg Upvote 0 Downvote Solution
