Question Will 3000mHz DDR4 RAM be compatible with a ASRock ATX Motherboard (B450 PRO4)
aarono123
Commendable
Jul 14, 2019
72
I ordered a ASRock ATX Motherboard (B450 PRO4) which supports DDR4-3200+(OC)/2933/2667/2400/2133. The RAM i ordered is 3000mHz. Will it be compatible? If not, there's an option for the RAM to be 2666mHz, but as you can see, the mobo supports 2667 so I doubt going as close as possible is not the right idea.
