Question Will 3200Mhz or 3000Mhz RAM work with i5 6400?
Dec 22, 2019
23
Hey
So I want to upgrade my RAM. I was thinkin' about 2x8GB with a frequency of 3200Mhz or 3000Mhz. My CPU is i5 6400 (2.7Ghz) and my motherboard is MS-7A15. Will it work?
Ty for help! :D
Dec 22, 2019
23
Overclocking cpu won't help. The motherboard itself is limited to 2133. So yeah, a potential waste going higher unless you plan to run them at 2133 temporarily until you upgrade motherboard.
Hai!
Oh, okay I but there is still a question. Right now I have 1x8GB 1866Mhz. Would it be a nice update if I upgrade it to 2x8GB 2133Mhz?
37
5
35
Dual channel will clearly increase performance in every situation! You can even see an increase of 5 to 10fps in games or even more. You should definitely buy the dual ram kit. Also, you could consider a z270 board to unlock XMP profiles and buy a kit of 16gb 3200mhz for 60 bucks. It might boost you a little more.
Latest posts
