Z Zemahh Aug 20, 2019 2 0 10 Aug 20, 2019 #1 the motherboard says that it only supports 2933mhz ram but says it supports 3200mhz(O.C) does this mean ill be able to use 3200mhz ram and 3000mhz ram in this motherboard, or does it mean that i can only get 2933mhz ram and overclock that to 3200?
NightHawkRMX Titan Ambassador Jan 1, 2018 18,638 4,007 81,540 Aug 20, 2019 #2 Yes it will work. Just put in the ram and turn on xmp or docp in bios and ram will run at 3200mhz. 2933 is the official spec, but 3200mhz will still work fine. Reactions: DMAN999 Upvote 0 Downvote
Z Zemahh Aug 20, 2019 2 0 10 Aug 20, 2019 #3 remixislandmusic said: Yes it will work. Just put in the ram and turn on xmp or docp in bios and ram will run at 3200mhz. 2933 is the official spec, but 3200mhz will still work fine. Click to expand... ok, thank you Upvote 0 Downvote
