jaguarskx :
OLED displays suffer from burn in issues where if an image is on the screen for too long then you will basically see an "imprint" of the image on the screen. It's great for watching movies since images generally do not linger for very long on the screen.
An example would be the Windows Taskbar that is always at the bottom of the screen unless you set it to autohide. Another example would be sports. While there is mostly constant movement on the screen, the one thing that is always on the screen during the game are the graphics showing the score. While the numbers may change from time to time, the "score box" is always there and it will burn into the OLED screen over time.
It is an inherent flaw with the technology itself much like how backlight bleed through is an inherent flaw with LCD screens / monitors.
Hello jaguarskx,
Thank your for your answer, but I am not looking for general information about OLED. I am already quite familiar with OLED technology, its pros/con, and I am 'a taker'.
Fact is that HP does propose the HP Spectre X360 (2nd generation) with an OLED display:
http://store.hp.com/UKStore/Merch/Product.aspx?id=F2T95EA&opt=ABU&sel=NTB
It is on stock, you can purchase it right now.
Fact is also that HP has recently introduced a 3rd generation of HP Spectre X360, with Kaby Lake processors, lighter and slightly smaller form factor, longer battery life and different connectivity. With the exception of the loss of SD-card port, I am very interested in this 'refreshed' version.
Fact is finally that, for the moment, this 3rd generation only sells with a FHD IPS display...while the previous generation did offer the choice between FHD IPS, QHD IPS and QHD OLED displays. But as this 3rd generation is brand new, it not clear if this will change...or not.
I know the drawbacks of OLED technology, but it did NOT prevent HP from selling the 2nd generation of Spectre X360 with an (optional) OLED display. Question is: will they do it again?
I tried to ask HP directly HP on Facebook and - unsurprisingly - did not get any answer. But maybe interviews/press release/rumors/... may give clues about HP strategy for this new generation.
