[SOLVED] Will 40 pin work with any 40 pins?
M5400 used a 1366 x768 Touch screen and the connector is in a different spot than that display so no it won't work.
This is like asking if a car has 4 wheels are all the parts interchangeable. 😉 When you say 40 pin connector it looks something like this.
Resolution
4 options
Backlight type
4 options
Display Size
5 options
Panel Type
4 options
Connector location
6 options
Built-in WIFI Antenna
2 options yes or no
With Routed Camera wiring
2 options yes or no
Touch screen or No Touch screen
2 options yes or no
How many different combinations do you have there? How many different ways are the wiring going to vary provided it has one or more custom options?
Resolution
4 options
Backlight type
4 options
Display Size
5 options
Panel Type
4 options
Connector location
6 options
2 options yes or no
2 options yes or no
2 options yes or no
Reactions: Taxici
