I know that questions have been asked alike.
But the answer varies.
People always saying better to have 26 amps on the 12V rail.
Quote:
[The HD4770 draws a maximum of 80 watts. 80 watts / 12 volts = 6.7 Amps. If the rest of your system is typical (a 100-watt CPU, 1HDD, 1ODD, mobo + ram), they will pull another 13 amps or so on the +12V under full load. So look at your PSU's label and see if it can deliver at least 20 Amps on the +12V. If it can, it should work.]
But what if i got 2 12v rails? 2 and each supply max 18a. Can i took it as 32a?
CPU: Q6600 95W
RAM: 2GB
1 hd and dvd drive
Motherboard: MSI p45 platinum
Power supply: SPI ATX 400-PN
Details:
OutputVoltage MinimumLoad NormalLoad MaximumLoad
+3.3V 0.5A 10.0A 28.0A
+5V 0.3A 7.0A 30.0A
+12V1 1.0A 7.0A 18.0A
+12V2 1.0A 8.5A 18.0A
-12V 0.0A 0.4A 0.5A
+5Vsb 0.0A 1.25A 2.5A
*+3.3V and +5V total output not exceed 180W
*+12V1 and +12V2 total output not exceed 348W
*+3.3V & +5V & +12V1 & +12V2 total output not exceed 385W
* Total output for this subject power supply is 400W
Efficiency: 70% minimum measured at normal AC mains
voltage and frequency with full load
Sorry for the rough data presentation.
Please tell me as i really worried about this.
CPU: Q6600 95W
RAM: 2GB
1 hd and dvd drive
Details:
+5V 0.3A 7.0A 30.0A
-12V 0.0A 0.4A 0.5A
