C cashrtns Commendable Jul 26, 2016 5 0 1,510 Jul 26, 2016 #1 My Specs. Cooler Master Thunder 450W PSU(6+2 Pin) Core i5 4440 3.1Ghz 8Gb DDR3 Ram 800Mhz Single Ram 1SSD 120Gb+2Tb SATA+500Gb SATA Will this PSU Be enough to work well with MSI Gaming X Gtx 1070. Will it damage GPU too much ?
Solution Dark Lord of Tech Jul 26, 2016 A GeForce GTX 1070 needs 30 amps on the 12v+ rail and a 500 watt power supply with 1 - 8 pin PCIE power connection. It can run it , has enough power , but the quality of the PSU is very poor. Recommend upgrade.
D dexxterlab97 Estimable Jul 4, 2016 2,147 1 3,465 Jul 26, 2016 #2 450W will work but I recommend getting a 500 Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,807 1,864 159,590 Jul 26, 2016 Solution #3 A GeForce GTX 1070 needs 30 amps on the 12v+ rail and a 500 watt power supply with 1 - 8 pin PCIE power connection. It can run it , has enough power , but the quality of the PSU is very poor. Recommend upgrade. Upvote 0 Downvote Solution
