Will 5850's in xfire mode will Run Crysis 2 at max DX11
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Hello all.
Can't find any benchmarhs for xfire 5850's. Wondering what the difference between DX10 and DX11 for graphics is and does it make that much of a difference?
Wondering if my system will be able to run Crysis 2 Max out at 1920x1200 -will be playing on Acer G24 Monitor. Even though I have 3 monitors hooked up. Only one is used for gaming.
Rig below:
My rig is OC'd to 4.0ghz.
Vidoe Card xfire is at STK clocks.
And video drivers up-to-date with the latested CCC and profiles.
Internals:
Mobo: Asus P6X58D-E
CPU: i7 930 LGA1366
CPU cooler: Noctua NH-D14
SSD: intell X25-M 80gig
HDD: WD Caviar Black 1TB 7200
GPU: Sapphire ATI Radeon 5850 x 2 (crossfire)
RAM: Crosair XMS3 Classic 6GB DDR3 1600mhz
PSU: Crosair 750Txw
Case: Antec 1200
Monitors:
Acer S243HL x2 (max res at 1920x1080)
Acer G24 (max res at 1920x1200)
Miscellaneous:
Keyboard: Logitech Gaming G110
Mouse: Razer Epic Naga
Mouse pad: Steelseries 4HD
Headset: Tritton AX180
DVD: Phillpes x22
OS:windows 7 Home premium
Cheers
Thanks for getting back to me about this. So I can play with the D11 patch with the Hardcore graphics update?
What is the difference in all these DirectX....sorry if I sound so noob. I really don't understand the difference.
Hey guys, I put the tessellation to 16x. playing at 1920x1200 [Full Screen mode]. Using DX11 patch + the High texture pack enabled.
Playing single player Campaign with V-sync on.
Extreme Setting: 60fps.
Hardcore Setting: 40fps
Should I leave V-sync on or off? 40fps seems playable at the moment. Will that change online?
Judging by my system specs and my FPS in campaign mode..what settings would you recommend I play at?
Cheers..
