Based on the spec of the motherboard and the RAM, in theory it should work. Four slots, 16GB max (4GB per slot).
The RAM isn't on the QVL list, and I don't see any QVL config with 8GB of RAM, which is a red flag for me. If it's not expensive, and/or you have an understanding vendor, you can buy, try and return if it doesn't work.
If RAM quantity over speed is your priority, there are listings in the QVL of 6GB, which presumably are 3x2GB, but disable the dual channel RAM config. That may be an option, if you can find another 2GB stick that matches your current RAM.
