I ismailjamalx11 Sep 13, 2018 13 0 10 Sep 16, 2018 #1 Just wondering if a 1080ti strix will fit in my case Case : deepcool genome II https://ibb.co/nujG2K
Solution Phazoner Sep 16, 2018 According to Newegg, the max GPU length is 330mm for the Genome II: https://www.newegg.com/Product/Product.aspx?Item=N82E16811853041 According to ASUS, the 1080Ti Strix length is 29.8cm: https://www.asus.com/es/Graphics-Cards/ROG-STRIX-GTX1080TI-O11G-GAMING/specifications/ So yes, it fits.
Phazoner Distinguished Jul 2, 2014 608 17 19,515 Sep 16, 2018 Solution #2 According to Newegg, the max GPU length is 330mm for the Genome II: https://www.newegg.com/Product/Product.aspx?Item=N82E16811853041 According to ASUS, the 1080Ti Strix length is 29.8cm: https://www.asus.com/es/Graphics-Cards/ROG-STRIX-GTX1080TI-O11G-GAMING/specifications/ So yes, it fits. Upvote 0 Downvote Solution
