hi everyone ,
im not electrician or expert on electrical so i want to make sure if im on safe side
i just bought APC 1200VA AVR (voltage regulator) but then i wondered whether the 1200VA is sufficient enough to handle (not overloading) all of my equipments?
I have tried to contact the APC support but it seems to be no reply from them
my equipment:
1. PC : - i5 4460 (processor)
- Palit Super Jetstream GTX 960
2GB (GPU )
-2x4GB DDR 3 RAM
-motherboard micro atx 1150
-1X 128GB SSD
-1X 1TB HDD WD BLUE
- PSU CoolerMaster MasterWatt
550 550W 80+ Bronze
-6X 120mm fans
- usb keyboard and mouse
- usb DAC AMP ifi zen DAC
according to outervision
load wattage : 344W
Recommend UPS rating :750VA
recommend PSU wattage : 394W
2. 2X Yamaha HS 5 Speaker specifications according to website for each speaker :
-output power 70W (LF :45W , HF : 25W)
-power consumtion 45W
3. Led Monitor Samsung 24Sr35 24inch (according to website 25watt)
thanks in advance
my equipment:
2GB (GPU )
-2x4GB DDR 3 RAM
-1X 128GB SSD
-1X 1TB HDD WD BLUE
550 550W 80+ Bronze
-6X 120mm fans
load wattage : 344W
thanks in advance
