[SOLVED] Will a 240 fit next to a 120 AIO?
Agentlekiller
26
Hi,
First timer so be gentle. I've got a NZXT H440 Matte Black Edition case and would like to know if a Kracken x63 will fit next to a M22 front or top? I'm Going for both cpu and gpu cooling.
No, because of the length of the radiators.
For example, on a 240mm rad, the radiator itself can be some 40mm longer. Trying to add a 120mm adjacent to it is going to be pretty difficult; you'll have to get creative... with some zipties.
Phaaze88
Ambassador
