Hi!
My mobo is a Gigabyte G41M- Combo with,
* 1 x 4-pin CPU fan header
* 1 x 3-pin SYS fan header
But I want at all 4 x case fans to be connected. & I thought of using a fan splitter for that single 3-pin header.
So, will the 3-pin header automatically regulate the fan speeds according to the system temperature?
& since I connect 3 x fans (parallel) simultaneously, will there be any problem in regulation?
And I know that I can do this by directly connecting to the Power Supply.
But I'm concerned about the noise that these 3 fans are going to make at full throttle.
Even though, can I directly connect those? Won't there be any there any voltage issues?
[PSU - PowerLogic Magnum Pro 275 (550W) with 3 x Molex (4-pin)]
