Question Will a 3090 work fine in a z170-a, with a 6700k? Or will there be bottlenecking?
May 31, 2020
18
Will the z170-a transfer enough power or wattage through its video card slot to the 3090? Im not too tech savvy
helper800
Unless you are playing at 4k and even at 4k you will be severely bottle necked with a 6700k. a 3090 gpu requires at a minimum 2 8pin PCIe power cables from the PSU in addition to the power from the video card slot. You need a very robust PSU to run a 3090 GPU without issues. I could try to help determine if your system is capable with more detailed information on your systems current PSU. Please include the brand, model number, and wattage of the PSU.
LolaGT
Proper
Oct 31, 2020
95
51
120
It would be dependent on your power supply as far as having enough, it takes a lot of juice.
While the 6700k might feed it if it was overclocked, out of the box speed will likely not do. The 3090 would be waiting on data, and making a card wait is when it will perform badly.
