Will a 430W PSU be enough for a i5-4690 and a GTX 960?
MrNinja418
16
I want to upgrade to an i5-4690 and a 960, at the moment i have a 430W PSU. I am wondering if this is enough. I don't want to spend another 50-60 dollars on a PSU if i don't have to, thanks.
Can't i put a 4690 on any lga1150 mobo with a 960?
What do you think is the best processor to go alongside with the 960. An i5 i'm talking about. I'm differentiating between the 4460, 4570, 4590, 4670, 4690, etc.
What brand of PSU do you recommend then? And i would also like to know what's wrong with it. I thought corsair was a good brand. Also what 960 do you recommend?
Corsair does not make their one psus so some of them are good and some of them are not. The cheaper ones are not good.
If you insist on the GTX960, get the cheapest one.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($189.99 @ NCIX US)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard ($65.98 @ Newegg)
Video Card: MSI GeForce GTX 960 2GB Video Card ($169.99 @ SuperBiiz)
Case: Rosewill Line-M MicroATX Mini Tower Case ($39.99 @ Amazon)
Power Supply: Antec Green 550W 80+ Bronze Certified ATX Power Supply ($49.99 @ Newegg)
Total: $515.94
Generated by PCPartPicker 2015-07-13 23:41 EDT-0400
Yes Gtx 960 + 4690 with a good quality 430w psu will work just fine, i build pc's for living and done that build for a client, it was with a EVGA 430w 80+ Power supply.. Hope this helps
