Will a 450 watt psu power a 1070 ti msi gaming
nolanoconnell2
19
I'm getting the gtx 1070 ti gaming by msi and a ryzen 5 1600 will my evga 450 bt bronze psu be enough with minimal cpu overclock? I used the outervision psu calc and it says it will at max use 430 watts with my 1600 clocked at 3.6mhz and my 1070 ti at 1834 mhz
Not safe.
Max efficiency for the PSU is at 50% useage. It remains 'OK' at 80%. 450 * .8 = 360w. At 360w it will actually waste around 16-19% (converted to waste heat). At max draw it will deliver a maximum of 360watt (20% waste heat). You should never run a PSU over 80%. As the temps go up, efficiency will continue to drop. As dust gets inside, efficiency will drop. You will only get 360w if it is in a sealed and refrigerated room.
I would suggest at least a 550w, ideally a 650w one which is a good quality.
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
I have a bias towards Seasonsics.
Not safe.
