Will a 4GB DDR3 1866MHz memory will work on a DDR3 1333MHz G41 Motherboard?
Well Not All Of The Ram Accepts Good With Downclocking .
If U Use 1866Mhz On 1333Mhz Mobo It Will Downclock To 1333Mhz But In Some Ram It Will Cause Some Issues And Some Few Conditions The Mobo Can Damage The Memory 🙁 If U Havent Afforded That 1866 Mhz Ram I suggest U at least Buy 1600Mhz If 1333Mhz Is Not Foundable
But If Not. In My Opinion Most Of Times It Will Run Fine .
Regards 😉
Regards 😉
I'm planning to buy a HyperX Fury 4gb 1866 for my soon G41 motherboard
