D dodostarforce Reputable Apr 13, 2014 66 0 4,640 May 9, 2014 #1 http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=583#spec my motherboard. says it only supports 3rd gen, will it still work?
Solution Danbuscus25 May 9, 2014 no, 4th gen intel cpus have a different socket, 1150, so it will not work.
Danbuscus25 Dignified Feb 15, 2014 5,368 0 13,960 May 9, 2014 Solution #2 no, 4th gen intel cpus have a different socket, 1150, so it will not work. Upvote 0 Downvote Solution
D de5_Roy Splendid Oct 14, 2011 7,159 0 26,960 May 9, 2014 #4 dodostarforce : http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=583#spec my motherboard. says it only supports 3rd gen, will it still work? here's it's cpu support list: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=583#cpu no 4th gen support. moreover, 4th gen haswell core i cpus use lga1150 socket while that motherboard uses lga1155 socket, making the cpus incompatible. Upvote 0 Downvote
D dodostarforce Reputable Apr 13, 2014 66 0 4,640 May 9, 2014 #5 damn, thanks for the feedback,. thats really annoying but thanks anyway Upvote 0 Downvote
