Will a 550w Power Supply work for this setup?
petermic
211
So, I am wondering if a 550w PSU will work with this setup.
CPU: FX-8350(Plan on overclocking to 4.5GHz wiith water cooler).
Memory: 16GB 1600MHz RAM(Plan on overclocking to 1866MHz).
Video Card: GTX 660 OC.
Mobo: Asus m5a99fx pro r2.0
I am running a Dual Monitor Setup.
Thank You in advance!
From the looks of it , and the fact that you are over clocking . I would go a bit more like a 700 or 800 . You might get away with a 500 for a while but I would not expect it to last long ... check this out . enter your specs to the detail. and use this to calculate your pc power demeands , it includes over clocking options for your cpu
http://www.extreme.outervision.com/psucalculatorlite.jsp
I'm planning on getting a cooler master. Do you think it will be ok even if I overclock to 4.5 GHz?
140 Watt video card 160 if you mean a 660ti
125 Watt processor
About 80 for everything else
another 35 or so for the overclock..
Most coolermasters are junk the V gold ones are good, Seasonic, XFX, Antec TPC just to name a few good ones.
