My psu has only one 6 pin pcie port and my gpu requires 2 8 pins so if i get a 6 pin to 2x8pin adapter will that affect the gpu or make it run slower than if it were connected to the psu natively
Look at it this way: using an adapter on a PSU is like using the donut spare tire on your car. Yes, it will work, but not for long. It is meant to just get you to a place where you can fix the tire.
Plus the GPU needs 2X 8 Pin...
The PSU only has 1X 6 Pin.... It takes 2X 6 pin to make 1X 8 pin.
