Qedrigord Dec 8, 2020 2 0 10 Dec 8, 2020 #1 Specs: GPU: AMD Radeon 6800 XT CPU: AMD Ryzen 5 3600XT RAM: 2x8 16 GB G.Skill 3600mhz STORAGE:Intel 660p M.2 nvme ssd and 7200rpm hdd Will a 650W power supply be enough to power this setup?
Solution siaan312 Dec 8, 2020 Qedrigord said: It is a Corsair RM650x Click to expand... It will handle it, but it's the lowest psu I would put with that rig.
siaan312 Splendid Jun 15, 2017 2,319 459 23,790 Dec 8, 2020 #2 This depends. What exact model is it? 650 watts is enough on paper, but, I would personally put a buffer on it, unless it was a best in class psu, say an HX650i, or similar. Upvote 0 Downvote
Qedrigord Dec 8, 2020 2 0 10 Dec 8, 2020 #3 siaan312 said: This depends. What exact model is it? Click to expand... It is a Corsair RM650x Upvote 0 Downvote
siaan312 Splendid Jun 15, 2017 2,319 459 23,790 Dec 8, 2020 Solution #4 Qedrigord said: It is a Corsair RM650x Click to expand... It will handle it, but it's the lowest psu I would put with that rig. Upvote 0 Downvote Solution
