B biskin157 Reputable Mar 4, 2014 5 0 4,510 Jun 26, 2014 #1 Title says it all. I just got my MSI 780 to realize that my CPU (AMD Phenom x4 965 BE) is heavily bottlenecking the GPU. So I want to upgrade to a 8350, so I was just wondering if my 650 watt 80+ Bronze would supply the enough power? Thanks, Adam
Solution bignastyid Jun 26, 2014 biskin157 : bignastyid : It's an ok unit(tier 3). http://www.tomshardware.com/answers/id-1804779/power-supply-unit-tier-list.html So would it be powerful enough to run those two components? Yes. But if you plan on overclocking you will want to upgrade to a higher end unit.
bignastyid Titan Moderator Jun 19, 2011 33,693 1,704 159,590 Jun 26, 2014 #2 Maybe. I would need to the make and model of the PSU, not all bronze rated 650w PSUs are created equal. Upvote 0 Downvote
B biskin157 Reputable Mar 4, 2014 5 0 4,510 Jun 26, 2014 #3 bignastyid : Maybe. I would need to the make and model of the PSU, not all bronze rated 650w PSUs are created equal. heres the PSU that I have http://www.newegg.com/Product/Product.aspx?Item=N82E16817182132 Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,693 1,704 159,590 Jun 26, 2014 #4 It's an ok unit(tier 3). http://www.tomshardware.com/answers/id-1804779/power-supply-unit-tier-list.html Upvote 0 Downvote
C coteau Distinguished Mar 12, 2008 26 0 18,540 Jun 26, 2014 #5 Pretty good site to get a general idea of how much power is recommended. eXtreme Power Supply Calculator Lite Upvote 0 Downvote
B biskin157 Reputable Mar 4, 2014 5 0 4,510 Jun 26, 2014 #6 bignastyid : It's an ok unit(tier 3). http://www.tomshardware.com/answers/id-1804779/power-supply-unit-tier-list.html So would it be powerful enough to run those two components? Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,693 1,704 159,590 Jun 26, 2014 Solution #7 biskin157 : bignastyid : It's an ok unit(tier 3). http://www.tomshardware.com/answers/id-1804779/power-supply-unit-tier-list.html So would it be powerful enough to run those two components? Yes. But if you plan on overclocking you will want to upgrade to a higher end unit. Upvote 0 Downvote Solution
