Will a 660 ti fit
Gamermixcat
11
Hi, I'm looking to buy a 660ti graphics card. But not sure it will fit in my pc. My mother board is a H81M-P33 and I have 500w power supply and my mini tower is called Cooler Master Elite 342. If you know something please reply. Thanks.
This case supports GPU up to 363 mm length. If your 66o ti is not longer (and I don't think so), it will fit. Mobo and PSU are also good enough (of course if PSU is good quality).
The 660ti is compatible with your motherboard and a 500W PSU is enough for it.
The dimensions for the CM Elite 342 are: 180 x 352 x 440 mm / 7.1 x 13.9 x 17.3 inch
http://www.coolermaster.com/case/mini-tower/elite-342/
Post a link to the GTX 660ti you are planning to buy so its dimensions can be compared to the case. (will likely fit)
If you are looking for a different cheap well performing card I recommend a GTX 750ti or a 1050ti. You can get very small models to fit all sorts of cases and they perform pretty well for most games depending on the rest of your spec.
example: https://www.amazon.co.uk/Zotac-GeForce-1050Ti-Mini-Graphics/dp/B01M8M5T4T/ref=sr_1_2?s=computers&ie=UTF8&qid=1495290346&sr=1-2&keywords=gtx+1050ti
