Will a 7950 fit in a SMALL case
sebastian7970
21
I wanted to build a pc in a small potable case (for instance: http://www.nox-xtreme.com/producto/coolbay-slim/1/) that could fit a 7950 with the PSU and everything else. The dimensions of the case are: 365 x 295 x 99 mm. Excuse me in advance if it may seem as a stupid question, I have never built a pc before.
In the possible situation that it won't fit in this case is there any other slim case that would do the job?
Thanks in advance
I think the length of this card is 11 inches right? 295 mm is equivalent so 11.6 so technically it should fit right? If this is not a viable option what would be the next smallest case I could fit a 7950 in?
Thanks!! I like the fractal case however its still a bit big for my taste. I am prepared to buy a GTX680 or 670 and sacrifice performance (my monitor is 2560 1440p) and price (in Spain the 7970 is ~100€ cheaper than 680) in order for it to fit in a smaller case, otherwise I will just buy the fractal with a 7950 or 7970. Would the 680 or 670 fit in the case I originally wanted (365 x 295 x 99m)? Thanks again for the quick answers!
This is the best solution but the price of it + shipping to Spain is too much I think. I have opted to use the Fractal design core 1000. Can someone please make any suggestions on my setup since I will be buying it in about 2 weeks. Here it is:
CPU: intel i5 3570(156€)
Motherboard: ASRock Z77 pro M4 (73€)
RAM: G skill ripsaws x ddr3 1600 pc3 2x4GB cl9(50€)
HDD: WD caviar blue 500gb sata3(40€)
GPU: Radeon 7950 OC boost vapor x 3GB (241€)
Case: fractal design core 1000 (30€)
Total= ~600€ (800$)
I will be gaming on a 2560 1440p monitor. No CPU overclocking and maybe GPU overclocking in future. I would really appreciate it if someone could suggest any upgrades or indicate what to downgrade (eg intel i5 3330 instead of 3570).
Thanks a lot Noob 12!!
I have decided to wait until haswell is out to build the pc so i still have time.
I also think that in the future i will want to SLI or CF. Would this case allow me to sli two 670 or CF two 7950? I know I'm being a bit picky but I just want to make sure that this pc will last quite a while.
I am 100% sure you can put 2 670s in a SilverStone SG09B but not sure if 2 7950s fit....
