Will a 7mm Solid State Drive fit in a regular 2.5in Drive bay?
Spinal_94
32
Hi,I am building a Mini ITX system and I am planning on putting an SSD as the Main drive and The SSD I am planning on buying is 7mm Thick.Would that have any effect on it fitting inside a regular 2.5In drive bay?.The Mini ITX case I am using is a Cooler Master Elite 130. Thanks for your help,This is my first SSD and I am not too sure if it will fit.
SSD:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820721108
CASE:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119286&cm_re=cooler_master_elite_130-_-11-119-286-_-Product
No it should mount fine in that case.
Where yellow box is:
