N _nitroz_ Reputable Nov 30, 2015 10 0 4,510 Nov 30, 2015 #1 Exactly what the title states, I know there have been similar questions, but none regarding the CLASSIFIED version of the card. Ive heard its a very big card, just wondering if it will fit in the 410. Thanks guys!
Solution bignastyid Nov 30, 2015 Yes, it will fit if you remove the drive cages. 9.06" (230mm) With Drive Cages 12.01" (305mm) Without Drive Cages The card length is 11.02" (280mm).
bignastyid Titan Moderator Jun 19, 2011 33,736 1,748 159,590 Nov 30, 2015 Solution #2 Yes, it will fit if you remove the drive cages. 9.06" (230mm) With Drive Cages 12.01" (305mm) Without Drive Cages The card length is 11.02" (280mm). Upvote 0 Downvote Solution
N _nitroz_ Reputable Nov 30, 2015 10 0 4,510 Nov 30, 2015 #3 @bignasty Thanks man! So the width and everything is fine too, right? Its gonna be the only gpu in there. Thx again Upvote 0 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,736 1,748 159,590 Nov 30, 2015 #4 Width shouldn't be a problem. Upvote 0 Downvote
N _nitroz_ Reputable Nov 30, 2015 10 0 4,510 Nov 30, 2015 #5 @bignasty Thanks man! have a good day Upvote 0 Downvote
