Will a 980ti fit?
xv3numbx
78
Mobo - asrock b75 pro3-m
Case- NZXT Guardian 921 RB ATX Mid Tower Case
Mobo looks like the Sata slots are in way haven't tried the other pci slot yet tho
Any help would be awesome thanks, will try again when home after work xp
Your case specs - https://www.nzxt.com/product/detail/109-guardian-921-rb-case.html - don't say how long vga card it will fit.
Which gtx980Ti? The reference card - http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-980-ti/specifications - is 10.5ins (267mm) long
Looks like your mobo will be OK - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157329 - but you might have to use right angle sata cables eg http://www.newegg.com/Product/Product.aspx?Item=N82E16812123282 if you want to use the bottom pci slot
Latest posts
