will a Asus 7970 DCUII top fit on my motherboard
mic009
7
Hey all, I'm looking for a graphics card and my interest fell on a second hand 7970 DCUII top edition. So here's my problem, I need to know if it will fit on my motherboard because there is a other lane next to mine main PCIE slot which I use right now and that slot is a bit higher, I don't know what kind of slot it is because I don't use it.
The card I have right now: http://www.asus.com/Graphics_Cards/HD7790DC2OC1GD5/overview/
My motherboard: http://www.asrock.com/mb/amd/970%20pro3%20r2.0/
I don't have any problems with the card I use right now, but that isn't a 3 slots card ofcourse. I have already checked al the other things before I buy this card, it will fit in my case and my PSU is strong enough to handle it but I can't seem to find out this problem.
Thanks in advance!
Yep should be good. It will probably cover up your other PCIE slot or atleast the PCI slot above it. Either way if you aren't using the two slots you are good. I likes me some 2nd hand 7950/7970 action. Good stuff.
